Log in or Sign up
Forums
RacingWeb Community
Motorsport Forum
Karting
มาดูเครื่อง 4 จังหวะ งามๆ กันครับ
Reply to Thread
Name:
Verification:
Please enable JavaScript to continue.
Loading...
Message:
<p>[QUOTE="gai08, post: 246019, member: 17600"]<font size="4">เอารูปมาชมกันอีก กับเจ้าเครื่อง 4 จังหวะตัวนี้...พร้อมกับรายละเอียดเพิ่มเติม..</font></p><p><br /></p><p>The Suter Vampire is a good 4-stroke engine, and has real racing heritage. The 4-stroke karting market is wide open at the moment, and the Suter Vampire fits quite nicely into the 4-stroke bracket that Biland has, until recently, dominated. </p><p><br /></p><p>Results in Europe already prove that the Suter Vampire regularly outperforms the Biland, and its success is really putting Biland under a lot of pressure. So I took the Suter Vampire, courtesy of Saxon Motorsport, out for a quick spin at Whilton Mill to see what all the fuss was about.</p><p><br /></p><p>When driving the Suter Vampire I found it slightly difficult to distinguish it from the Biland to be quite honest. The performance characteristics are very similar, but there are slight differences. The Suter Vampire does have more bottom end power than the Biland, but it does lack a bit of top end grunt. The Vampire is really in its element at the lower revs, and it really loves to pull hard out of the slow corners. The Vampire just has masses of torque. </p><p><br /></p><p>Even though we were on the wrong gearing, which meant I was hitting the rev limiter too early along the main straight at Whilton before Christmas Corner, the engine wasnt pulling very hard at high revs. The power just faded at high rpm. Even with this in mind, you can expect very similar, if not better, laptimes with the Suter Vampire over the Biland..</p><p><br /></p><p>One of the weirdest things I found with this engine was that it was stupidly smooth. Being a single cylinder engine you would expect a little vibration and brutality, but the Vampire was just silky smooth.</p><p><br /></p><p>In the sound department the Vampire sounds a lot like the Biland. It doesnt seem as throaty as the Biland, but you would find it hard to tell the difference between the two if there was a grid of both.</p><p><br /></p><p>In pictures, the Suter Vampire can look horrifically gigantic, but in reality it actually sits in the kart much better than you would expect. Its not over bearing, and the integrated oil tank is also a neat touch too.</p><p><br /></p><p>Performance aside, I didnt get that magical buzz with the Suter Vampire that I get with a 100cc engine, or something like the Aixro XR50. The lack of top end speed meant I didn't get that 'edge of your seat' excitement going into corners. </p><p><br /></p><p>However, there is no doubt that the Suter Vampire is fast, and it's a very good Biland replacement. I am also in no doubt that current Biland owners will absolutely love the Suter Vampire.</p><p><br /></p><p>Link <a href="http://www.karting1.co.uk/suter-vampire.htm" target="_blank" class="externalLink ProxyLink" data-proxy-href="http://www.karting1.co.uk/suter-vampire.htm" rel="nofollow">http://www.karting1.co.uk/suter-vampire.htm</a>[/QUOTE]</p><p><br /></p>
[QUOTE="gai08, post: 246019, member: 17600"][SIZE="4"]เอารูปมาชมกันอีก กับเจ้าเครื่อง 4 จังหวะตัวนี้...พร้อมกับรายละเอียดเพิ่มเติม..[/SIZE] The Suter Vampire is a good 4-stroke engine, and has real racing heritage. The 4-stroke karting market is wide open at the moment, and the Suter Vampire fits quite nicely into the 4-stroke bracket that Biland has, until recently, dominated. Results in Europe already prove that the Suter Vampire regularly outperforms the Biland, and its success is really putting Biland under a lot of pressure. So I took the Suter Vampire, courtesy of Saxon Motorsport, out for a quick spin at Whilton Mill to see what all the fuss was about. When driving the Suter Vampire I found it slightly difficult to distinguish it from the Biland to be quite honest. The performance characteristics are very similar, but there are slight differences. The Suter Vampire does have more bottom end power than the Biland, but it does lack a bit of top end grunt. The Vampire is really in its element at the lower revs, and it really loves to pull hard out of the slow corners. The Vampire just has masses of torque. Even though we were on the wrong gearing, which meant I was hitting the rev limiter too early along the main straight at Whilton before Christmas Corner, the engine wasnt pulling very hard at high revs. The power just faded at high rpm. Even with this in mind, you can expect very similar, if not better, laptimes with the Suter Vampire over the Biland.. One of the weirdest things I found with this engine was that it was stupidly smooth. Being a single cylinder engine you would expect a little vibration and brutality, but the Vampire was just silky smooth. In the sound department the Vampire sounds a lot like the Biland. It doesnt seem as throaty as the Biland, but you would find it hard to tell the difference between the two if there was a grid of both. In pictures, the Suter Vampire can look horrifically gigantic, but in reality it actually sits in the kart much better than you would expect. Its not over bearing, and the integrated oil tank is also a neat touch too. Performance aside, I didnt get that magical buzz with the Suter Vampire that I get with a 100cc engine, or something like the Aixro XR50. The lack of top end speed meant I didn't get that 'edge of your seat' excitement going into corners. However, there is no doubt that the Suter Vampire is fast, and it's a very good Biland replacement. I am also in no doubt that current Biland owners will absolutely love the Suter Vampire. Link [url]http://www.karting1.co.uk/suter-vampire.htm[/url][/QUOTE]
Log in with Facebook
Log in with Twitter
Log in with Google
Your name or email address:
Do you already have an account?
No, create an account now.
Yes, my password is:
Forgot your password?
Stay logged in
Forums
RacingWeb Community
Motorsport Forum
Karting
Home
Home
Recent Posts
Recent Activity
Authors
Forums
Forums
Search Forums
Recent Posts
Classifieds
Classifieds
Search Classifieds
Recent Activity
Top Rated Traders
Media
Media
Members
Members
Notable Members
Registered Members
Current Visitors
Recent Activity
New Profile Posts
Menu
Search titles only
Posted by Member:
Separate names with a comma.
Newer Than:
Search this thread only
Search this forum only
Display results as threads
Useful Searches
Recent Posts
More...
