Japanese Car Clubs
Daihatsu Club
ผู้ใดใช้ Daihatsu Opti บ้างจ๊ะ
<p>[QUOTE="mira_rungsit, post: 434125, member: 1973"]Daihatsu Opti.....yes" OK</p><p><br /></p><p><img src="http://autobazar.od.ua/brands_marki/daihatsu_opti.jpg" class="bbCodeImage wysiwygImage" alt="" unselectable="on" /></p><p><br /></p><p><img src="http://www.microcar.org/carspecs/daihatsuopti.gif" class="bbCodeImage wysiwygImage" alt="" unselectable="on" /></p><p><br /></p><p><br /></p><p><u>1997 Daihatsu Opti </u></p><p><br /></p><p>Year........ 1997 </p><p>Make ........Daihatsu </p><p>Model.......... Opti </p><p>Engine .........Location Front </p><p>Drive ....................Type Front Wheel </p><p>Weight ...............710 kg | 1565.6 lbs </p><p><br /></p><p><u>Engine </u>   </p><p>Engine Configuration...........I </p><p>Cylinders ................3 </p><p>Aspiration/Induction............Normal </p><p>Displacement ................659.00 cc | 40.2 cu in. | 0.7 L. </p><p>Valves ..................12 valves. / 4 valves per cylinder. </p><p>Horsepower................ 55.00 kw (74.7 HP) @ 7500.00 RPM </p><p>Torque................. 56.00 NM (41.3 Ft-Lbs) @ 4000.00 RPM </p><p>HP to Weight Ratio........... 21.0 LB / HP (Vehicles with similar ratio) Vehicles with similar horsepower and weight </p><p><br /></p><p><u>Dimensions</u>    </p><p>Seating Capacity 4 </p><p><br /></p><p><u>Exterior </u></p><p>Length............ 3395.001 mm | 133.7 in. </p><p>Width .............1475.001 mm | 58.1 in. </p><p>Height.............1405.001 mm | 55.3 in. </p><p>Wheelbase............2360.001 mm | 92.9 in. </p><p> Vehicles with similar dimensions</p><p><br /></p><p>:sad::sad::sad::sad:[/QUOTE]</p><p><br /></p>
[QUOTE="mira_rungsit, post: 434125, member: 1973"]Daihatsu Opti.....yes" OK [IMG]http://autobazar.od.ua/brands_marki/daihatsu_opti.jpg[/IMG] [IMG]http://www.microcar.org/carspecs/daihatsuopti.gif[/IMG] [U]1997 Daihatsu Opti [/U] Year........ 1997 Make ........Daihatsu Model.......... Opti Engine .........Location Front Drive ....................Type Front Wheel Weight ...............710 kg | 1565.6 lbs [U]Engine [/U] Engine Configuration...........I Cylinders ................3 Aspiration/Induction............Normal Displacement ................659.00 cc | 40.2 cu in. | 0.7 L. Valves ..................12 valves. / 4 valves per cylinder. Horsepower................ 55.00 kw (74.7 HP) @ 7500.00 RPM Torque................. 56.00 NM (41.3 Ft-Lbs) @ 4000.00 RPM HP to Weight Ratio........... 21.0 LB / HP (Vehicles with similar ratio) Vehicles with similar horsepower and weight [U]Dimensions[/U] Seating Capacity 4 [U]Exterior [/U] Length............ 3395.001 mm | 133.7 in. Width .............1475.001 mm | 58.1 in. Height.............1405.001 mm | 55.3 in. Wheelbase............2360.001 mm | 92.9 in. Vehicles with similar dimensions :sad::sad::sad::sad:[/QUOTE]
Japanese Car Clubs
Daihatsu Club
