ระยะวาล์ว2T
Discussion in 'Nalam Club' started by somruk_aram, Mar 2, 2012.
  1. somruk_aram
    somruk_aram New Member Member
    อยากทราบระยะการตั้งวาล์วไอดีไอเสีย เครื่อง2T
  2. becaveman
    becaveman New Member Member
  3. becaveman
    Common settings
    Bore x Stroke 85.0x70mm (3.346x2.756")
    Displacement 1588cc (96.9ci)
    Compression ratio T-U 9.0
    Compression ratio 2T 8.5
    Compression ratio 2T-U 9.0
    Compression ratio 2T-GEU 8.4
    Compression ratio 12T 8.5
    Compression ratio 12T-U 9.0
    Compression ratio 3T-U 9.0
    Compression ratio 13T 8.5
    Inlet valve opens 16° BTDC
    Inlet valve closes 54° ABDC
    Exhaust valve opens 58° BBDC
    Exhaust valve closes 12° ATDC
    Inlet valve clearance - hot 0.204mm (0.008")
    Inlet valve clearance - cold 0.178mm (0.007")
    Exhaust valve clearance - hot 0.331mm (0.013")
    Exhaust valve clearance - cold 0.305mm (0.012")
    Timing 2T 10° BTDC at 600rpm
    Timing 2T-C auto 5° BTDC at 650rpm
    Timing 2T-C manual 5° BTDC at 750rpm
    Firing order 1-3-4-2
  4. somruk_aram
    ขอบคุณทุกท่าน
